DYNA MYTE 4800 / MITSUBISHI MELDAS_500 ATC & SPINDLE problems
Results 1 to 1 of 1
Thread: DYNA MYTE 4800 / MITSUBISHI MELDAS_500 ATC & SPINDLE problems
    Joaquin_87's Avatar
    Aug 2018
    Exclamation DYNA MYTE 4800 / MITSUBISHI MELDAS_500 ATC & SPINDLE problems
    Hello,
    I have a DYNA MYTE 4800 with MITSUBISHI MELDAS 500 control. I'm not sure, but I think that the model is old and discontinued. Well, I've two problems with this CNC:
    1./ SPINDLE
    In MDI mode I turn on the spindle and works ok, but when a change to HANDLE mode the spindle turns off right away. I not sure if that is a coding problem or wire connecting PCB problem (electronic issue).
    2./ ATC-MAGAZINE
    In MDI mode I enter the tool code for automatic change, for example, T10 M6, but the panel shows me this failure code:
    'P290 IF SNT. ERROR'
    MDI EDIT
    Attached Thumbnails Attached Thumbnails DYNA MYTE 4800 / MITSUBISHI MELDAS_500 ATC & SPINDLE problems-meldas500_screenpanel-jpg   DYNA MYTE 4800 / MITSUBISHI MELDAS_500 ATC & SPINDLE problems-atc_magazine-jpg   DYNA MYTE 4800 / MITSUBISHI MELDAS_500 ATC & SPINDLE problems-mitsubishi_control-jpg
