Cnc router
Results 1 to 3 of 3
Thread: Cnc router
    Default Re: Cnc router
    When you generated your G&M code did you select the correct post-processor? If you are using a program like VCarve, you have to select your corresponding machine/manufacturer so that it outputs the code in the correct format (I am oversimplifying this a bit).
    386281's Avatar
    Oct 2019
    Very new to CNC spork What sort of CNC bit would be best to drill a large number of 1/8 inch holes in copper? I am making a 20 foot long by 8 inch wide cover for one of the gutters on my house.
    Member awerby's Avatar
    Apr 2004
    Use a drill bit for that.
Cnc router
Cnc router
