Help! DSLS 3000 cable (X axis) broke at the little clip on the end of the encoder
Hi, guys and gals,
I have a DSLS 3000 that the cable on the X axis broke at the little clip on the end of the encoder on the motor. There's a black, green, white, and red wire coming from the cable itself. It was kind of mangled when I pulled it off and I can't tell which wires went in what order. It also doesn't look to be in the same order as the Z and Y axis so if any of you could look at yours and let me know what order it should be from the "flat" side of the clip for the X axis?
It's a 5 position clip (anyone know what these clips are called)?
Thanks for anyone's help as Taig is closed and I need to get her running!
Dave-
