Setting file for Taig mill with ball screws?
Results 1 to 7 of 7
Thread: Setting file for Taig mill with ball screws?
    May 2006
    NORWAY
    Default Setting file for Taig mill with ball screws?
    I´ve just bought a new Taig mill with ball screws. Can anybody here provide me with a file with the right config. settings for this machine?
    May 2006
    NORWAY
    Default Re: Setting file for Taig mill with ball screws?
    The file I look for is the mach3mill xml in the root directory of mach3 program. If anybody here has a taig mill with ball screws, can you please attach a copy of this file to this tread?
    Member awerby's Avatar
    Apr 2004
    Where did you get this mill? If it's a new Taig, it should have come with a CD that has all the files you need. Did it have a binder with instructions? In the binder, there's a plastic sleeve that should have the CD in it.
    May 2006
    NORWAY
    I bought it from deepgrove on ebay and there wasn´t any info in the sending. I´ve tried to contact him, but haven´t got any answer so far..
    Jun 2011
    For Taig's Ballscrews...
    4064 steps per inch
    Apr 2004
    That may or may not work with the Deepgroove control, which is different from Taig's half-stepping controller box. If you're setting this up by hand, you need to multiply the number of steps in a full revolution of the motor (200, usually) by the pitch of the screws (5 per inch, for the ball screws Taig uses) and the microstepping factor (2, for Taig's controller). That comes to 2000, but I'm not sure how many microsteps Deepgroove uses. The OP, being in Norway, will probably need to convert to steps/mm, since that's the unit commonly in use there. That comes to approximately 78.74, if you've got Taig's controller, but the actual number is longer.
  7. #7
    May 2006
    NORWAY
    I have now got an answer from deeproove. He sent me a link that I have to look through in order to find out the settings.
