I found some useful info on Google.
I have used this CNC Taig mill for 10 years. I would start having belt problems and realign and it would work.
Now I am having problems and it looks lined up to me, but the first thing happens is the belt twists and then it goes under a load and breaks.
Is there any info on a way to line this up besides eyeballing it?
Thanks,
David L. Aery
www.hooksolutions.com
David L. Aery
First check the motor support is square to the Headstock.
Next I use my Starrett #13 adjustable 4" sqaure to check alignment.
Place the body on the Headstock extrusion.
Now use the blade to check the belt alignment..
Stuart
Good Luck
thanks! that did the trick. my pulley was too low.
David L. Aery
