Newbie help please
Results 1 to 3 of 3
Thread: Newbie help please
    Member Fixwheelmad's Avatar
    Dec 2019
    Default Newbie help please
    I need help on motor setup, I’ve used a Electra beckum induction motor and switch gear, it’s a four wire 240v 2800rpm motor. Question it spins the wrong way, I could turn the motor round, but wanted a tight setup, also advice on type of speed controller, very eager to get advice so to get using it
    • #2
      Member awerby's Avatar
      Apr 2004
      Default Re: Newbie help please
      I assume this is for the spindle, right? Some induction motors will reverse directions, others won't. To find out, remove the plate that covers the wire inputs. If it's reversible, there should be a diagram showing which wires to switch.
      Induction motors aren't susceptible to speed control; they run at fixed speeds, like 1725 or 3450 RPM. You can set up a pulley cluster to get different speeds, with torque multiplication as a bonus. If you want variable speed, either get a 3-phase motor and run it from a Variable Frequency Drive or a DC motor run through a PWM controller.
    • #3
      Dec 2019
      Thanks will check later and confirm the wiring, cheers
    Newbie help please
    Newbie help please
