Stock Drive Products. https://www.sdp-si.com/products/Timi...index-2018.php
Can anybody here tell me the best option for pulley wheels and belt in order to mount a Consew CSM1000 Sewing Servo Motor to the original taig spindle block? Any links to an ebay seller or some other inexpensive dealers would have been fine.
A lazy man does it twice.
Anyone have part numbers on the ones that fit?
(closest fit)
The link above is the index to the entire web-store.
I have not completed boring out my pulley so I can't comment on efficacy, but I referenced this link: https://trains.socha.com/2018/11/tai...mach-mill.html
20XL037-3FA7 Imperial Pitch Pulley -- 20 teeth, 5/8" bore
40XL037-6A6 Imperial Pitch Pulley -- 40 teeth, 1/2" bore
142XL037G Imperial Pitch Belt
One of the pulley is type 3F and the other type 6. What does that mean? Do you think they both will fit the same belt?
And I see the 40xl pulley has a bore on 1/2 inch but the shaft on Consew is 15mm. Do you think this will be a better choice and fit to the belt?
https://www.ebay.com/itm/40XL037-Alu...UAAOSwyO1asyIY
My Taig Mill's spindle measures 15.9mm, and a 16mm pulley fits ...but sloppy, so it wobbles when the set screws are tightened.
(throws it off center just slightly)
Same slop problem with the Consew, which (mine) has a shaft measuring 14.96mm and a stock 15mm pulley fits but sloppy.
The pulleys seem to be bored slightly oversize.
I guess I'll need to get some more pulleys, get undersize pulleys and see if I can find someone with a lathe that can/will bore them to proper fit.
(sigh, ya, shoulda bought a lathe I guess)
Yeah that can be done and many do that,but I'd prefer to get a pulley (or modify a pulley) to fit properly without a work-around like shimming.
I've ordered a couple more pulleys and that will take care of it.
