Wiring setup for sewing machine motor?
Results 1 to 5 of 5
Thread: Wiring setup for sewing machine motor?
    May 2006
    NORWAY
    Default Wiring setup for sewing machine motor?
    Do I need to insert the foot pedal wire to the control box in order to get it to work or will it be possible to just short-circuit some of the contact points with a jumper?
    Dec 2003
    Default Re: Wiring setup for sewing machine motor?
    Depends on the type of motor, the older ones were simple Universal motors, now BLDC are usually used.
    May 2006
    NORWAY
    Quote Originally Posted by Al_The_Man View Post
    I have the csm2000. I tried to get it to run, but it will only do a few rotation at a very low speed and then it stops up. I need to swich of and on the 0/1 button in order to have it to run again, but then the same thing happens.
    What may be wrong?
    Jun 2011
    Have you replaced the foot-pedal with a potentiometer?
    How is it wired?
    The motor must have the pedal or pot in the off position to "ARM"...this is the safety interlock system....
    Then you can adjust the pedal/pot to desired speed..
    Stuart
    May 2006
    NORWAY
    Quote Originally Posted by sclelectronics View Post
    How is it wired?
    Stuart
    Here is a link to another thread where I got a solution.
