spindle stop / mount test indicator
Results 1 to 3 of 3
Thread: spindle stop / mount test indicator
    Jan 2016
    Default spindle stop / mount test indicator
    Seems like a silly question, but: how to you properly stop the spindle from spinning when using a test indicator?
    Like in this video:
    Or if someone has a different method entirely would be interested in that as well.
    I have this indicator set from LMC fwiw:
    https://littlemachineshop.com/produc...ProductID=2925
    Jan 2016
    Default Re: spindle stop / mount test indicator
    No one?
    Feb 2010
    On my Taig, I jam a piece of foamcore between the pulley and spindle body to prevent the spindle from rotating (low-tech but it works). You could also machine a spindle lock that uses a wrench head to lock the ER16 nut in place, like so:
    Taig Spindle Lock
