Your an innovator, nobody has made t nuts before. ..
Sent from my SM-G900T using Tapatalk
Been thinking about some 1/4-20 hold-down solutions to compliment my 10-32 stiff, mainly for compatibility with some 1/4" accessories I have.
Toying with a few options,
- T-nuts: Raised nut design, also will serve as hold-off (maybe only raised 1/8")
- T-bolts: Some off the shelf 1/4 hex head bolts + "head carriers" to prevent spin and contact with slot walls
Some simplified drawings I made real quick in MS paint, sorry, CAD license is being used by someone for "real work" at the moment.
5/16 would be be great too, but would require even more elaborate workarounds, prob gonna focus 1/4-20 for now.
Wondering mainly if anyone has tired similar with/without success.
I'm having a hard time seeing how the I beam shaped nut would be used. How would it be secured to the table?
They would secure like a regular nut, but the part couldn't be in contact, so I was wrong about "and could be used as a hold-off". Given that, maybe they aren't worth the trouble. I may look at something more like a mini-fixture table.
But I think the hex head "carriers" will work out. Currently thinking something like this (drawn to scale). Basically it just prevents turning and the hex head digging into the t-slot walls. Could get fancier with the pocket design if it turns out to have durability issues, but would need to use a smaller end mill.
