Need Help! very rough axis movement while cutting
Results 1 to 4 of 4
Thread: very rough axis movement while cutting
    Jul 2017
    Default very rough axis movement while cutting
    Can anyone help me? I built a t-slot CNC (~3ft x 4ft table) and while traversing the table or jogging the machine, it runs smoothly enough, but when running g-code or cutting a file, it is like the bearings are running over gravel and severely affects the resulting part. I can’t figure out if this is a mechanical flaw or a problem with my configuration settings. I’m currently running at 1/8 microstepping. I switched from 10 microstepping per full step to reduce any likelihood of missing steps. I can upload a video if you think you might be able to help.
    Member awerby's Avatar
    Apr 2004
    Default Re: very rough axis movement while cutting
    It sounds like there's something wrong with the motors or drives, or perhaps the software settings that are controlling them. What motors, drivers, and power supply are you using on this machine? What are the velocities and accelerations set at? What are the feedrates when you run a G-code program, and does it work any better at lower speeds?
    Jul 2017
    I’ve reduced max velocities and max accelerations to 1200mm/min and 20mm/min. I’ve looked repeatedly at my axes and have been unable to locate loose screws or binding. I also don’t understand why it wouldn’t do that while jogging the axes
    Jul 2017
    Just talked to someone in another group, and it may be that I left my machine in exact stop mode rather than constant velocity. I’m going to check that out when I get back to the shop. I thought I had it on CV, but maybe not.
