Touch Probe
Results 1 to 16 of 16
Thread: Touch Probe
    Jun 2007
    Engerland
    Default Touch Probe
    I've just taken delivery of a touch probe from this chap :-
    http://www.machsupport.com/forum/ind...ic,5004.0.html
    My knowledge of lektronix extends to red cable is + (usually) !
    Can anyone who's fitted one or similar give an indepth method of connecting it before I let the smoke out???
    Dec 2003
    What about the PDF installation instructions he mentions?
    Member jalessi's Avatar
    Feb 2007
    Post
    The white wire is common, the red connects to your probe input pin.
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jun 2007
    Engerland
    Quote Originally Posted by Al_The_Man View Post
    You mean this . . .
    Attached Thumbnails Attached Thumbnails Touch Probe-probe_brochure_small_size-pdf
    Feb 2007
    Post
    3.5mm wiring.
    Attached Thumbnails Attached Thumbnails Touch Probe-3-5mm-jpg
    Dec 2003
    I guess it comes with the miniature phono jack?
    The circuit just shows a string of N.C. contacts so the correct polarity is only required for the LED to operate when the probe has touched off, you can't really screw anything up as if you had the wire pair crossed it would just mean the LED would not light.
    Jul 2006
    Oooh!
    Gotta get me one of those
  8. #8
    Jun 2007
    Engerland
    Ok, now I know what the wires are . . . where do I put them???
    This is the bit where the smoke comes out !
    I've read that they need to connect to pin 11 of the parrallel port ?
    How, What, Why, When, Where ?
  9. #9
    Jul 2003
    This thread should help. Have a read and post back if still unsure
    http://www.cnczone.com/forums/showthread.php?t=84671
    /M
  10. #10
    Jun 2007
    Engerland
    I really am a numpty when it comes to lektronix
    Is Board 1.jpg what I'm plugging into?
    Now the hard bit, I have 3 wires from the probe, Red, White & a naked shield Cable 1.jpg, will all 3 be used? What do I need to connect to the plug - Plug 1.jpg?
    Attached Thumbnails Attached Thumbnails Touch Probe-board-1-jpg   Touch Probe-plug-1-jpg   Touch Probe-plug-2-jpg   Touch Probe-cable-1-jpg
  11. #11
    Dec 2003
    Pin 2-red & 3-white.
    Take the shield to ground.
    Your plug has only two active pins so if you have to find a ground for the shield.
    As long as the socket you show has the same pin out as the second JPG.
    Jun 2007
    Engerland
    I thank you all, I really am a complete numpty when it comes to lektronics.
    Having read through the posts I salvaged a suitable connector from an old PC fan & sanded it down to fit, the problem of how to connect such tiny & intricate wires was solved by junking the supplied female jack connector & purchasing a replacement from Maplins where the wires could be soldered directly to the jack.
    Plugged it in & fired her up, touching the probe illuminates the probes LED & the 'digitise' LED lights in Mach3's diag window. And no smoke !
    Eureka, after a bit of experimentation with the Mach3 digitise wizard I've set it off on probing a complex part I've been wanting to copy for ages.
    Although this probe is going to save me lots of money it's also going to cost me a lot too, it's going to take about 3 days to create a point cloud on this part so I'm looking to buy/build a simple 3 axis machine pureley for probing.
  13. #13
    Default Re: Touch Probe
    Hi All
    Does anyone know the "Magic Sauce" that Cliff uses in his ITTP probe.
    It's the contact preservative on the contacts.
    I want to try it on my Centroid probe to help keep the contacts
    in shape. Now I clean them with Acetone and then apply
    CRAMOLIN. Any ideas appreciated.
  14. #14
    He mentioned - do not remember the source (video, blog, online manual,...?) - that it is a proprietary formula he developed and does not plan to share, at least at this time.
  15. #15
    I have a friend at NASA. I'll find something.
  16. #16
    Hello everyone,
    can you guys share what gcode you use to probe X, Y and Z faces ?
    I purchased an Syil V5 and Syil X7, both with LNC controllers, both have a wired Pioneer TP400 probe.
    I found some probing files saved already in the machine, but I had some unpleasant surprises with the one probing the corner of a part (both X and Y), this is why I ask anyone around that uses a Syil machine, preferably with a LNC controller, to share their probing workflow and gcode.
    Thank you
Touch Probe
Touch Probe
