Looking for Syil X4 standard, mach3 config xml.
Results 1 to 7 of 7
Thread: Looking for Syil X4 standard, mach3 config xml.
    Member SuperUserg's Avatar
    Jan 2021
    Default Looking for Syil X4 standard, mach3 config xml.
    Hello, I just acquired a 2012 Syil X4 standard with 4th axis and automatic oiler. I am looking for a Mach3 config that's up to date-and working with my machine.
    It's unfortunate that Syil doesn't support the x4 anymore, it really isn't that old in machine years.
    Member Dave2024's Avatar
    Apr 2024
    Default Re: Looking for Syil X4 standard, mach3 config xml.
    I need one of these too if anyone comes across it? Can get everything working except for the spindle from software. Otherwise have to manually turn spindle on select direction and set RPM before running code then manually turn it off when done. Is annoying
    Nov 2013
    here's the one I was using and a new one from SYil
    https://1drv.ms/f/s!AjsCINWqzm7ChaAQ...2Cp1g?e=3Mkxhs
    Nov 2013
    do you not think it worthwhile to update from a parallel port? They were ALWAYS a bit quirky even back when parallel ports were common....but it worse now that they are not common.
    There are any number of parallel port driver boards out there, but only a few that strictly adhere to the original IEEE spec and ONLY those will work.
    Craig
    Member bravernoe's Avatar
    May 2024
    Hi Craig,
    You're absolutely right. Parallel ports were indeed quirky back in their heyday, and the situation hasn't improved with their obsolescence. Updating from a parallel port to a more modern interface is definitely worthwhile
    Member neilw20's Avatar
    Jun 2007
    Quote Originally Posted by bravernoe View Post
    Hi Craig,
    Easy. Stay offline and use Windows XP!!
    Windows 7: Get into the scheduler and turn off all of the crap.
  7. #7
    Nov 2013
    yep and rub two sticks together to start a fire...
    Craig
  8. #8
    Nov 2013
    Desktop has windows 7, but the machine is air gapped...
    I got the machine working. I had accidently plugged the Z limit switch cable to the wrong plug.
    Now however, the spindle is making more noise than I remember and the speed occasionally goes very high and then back down again.
    Bad connections on encoder feed?
    Should actual RPMs appear on the Mach3 control panel?
    How tight should drive belt be? It is a ribbed belt, and I didn't go crazy on the tightness, but maybe it should be looser?
    These 120v spindle drive boards are no longer available.
    Are there any good ways to replace the spindle control board, while still using the 5 axis board and axis drivers?
    Any reasonable options to replace 1100w spindle motor?
    Thank you,
    Bryan
