Syil Super X3
Results 1 to 7 of 7
Thread: Syil Super X3
    Jul 2007
    Default Syil Super X3
    Any Super X3 user in southern California? I plan to buy Super X3 CNC, i need help. Thanks
    Member neilw20's Avatar
    Jun 2007
    Default Sorry. Too far.
    Quote Originally Posted by tranbell View Post
    I'm in Melbourne Australia.
    Very happy with new Super X3 CNC with all bells and whistles. (4th axis, pump)
    You don't need help. Just start playing with it. Mach3 makes it work well.
    Registered metalworkz's Avatar
    Oct 2006
    Modesto, CA U.S.A.
    I am at Modesto,CA with my SX3. Still a bit far from southern CA.
    Regards,
    Wes
    Jul 2007
    Hi all,
    I properly go with super X3 professional packet after researched several brands such as CNC Jr. Master, Max NC… I also like Tormach machines (It has Y travel 9.5” compare with Super X3 travel 6.3 or 6.9), but it’s more expensive than Super X3.
    So far you guys very happy with super X3. I’m glad to hear that. Anything I need to know before I place the order for the machine? This is my first time to buy little CNC mill. Please advice. Thanks
    I like to see the machine before purchasing. But Syilamerica did not have any dealer or show room in Orange County California.
    Regards,
    Tran
    Jun 2007
    Hi all,
    Regards,
    Tran
    Tran.
    I bought mine 'blind'. Quality very good. Make sure limit switch leads are well supported and protected. Y limit switch lead should go around the tower, to avoid crossing the Y leadscrew area. Makes sure Z limit lead is not strained. Crimping tool used on crimped leads was not the correct one for most or all the connectors. They all need checking for security. Use minimum 1GHz PC with XP and standard parrallel port. No mechanical issues. Tweaking and tunng the Mach3 software settings give you some instant hands on learning.
    Nothing a days fiddling won't fix. The installation instructions show how to get slide the bed off the machine to clean shipping protection. Do this after you power it up so you can move each axis electrically. Thats when you tidy the cabling. All low voltage, so it is safe.
    Regards.
    Neil.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. THREE ways to fix things: The RIGHT way, the OTHER way, and maybe YOUR way, which is possibly a FASTER WRONG WAY!
    Apr 2006
    China
    you can email to syilamerica to display more video for you.
    syil china
    Direction,Commitment,Follow through
  7. #7
    Member Maytag's Avatar
    Aug 2023
    Default Re: Syil Super X3
    Can I still get information about my old Super X 3 machine?
Syil Super X3
Syil Super X3
