They use different controls on some of the same machines, so a photo of the layout might only at best be generically helpful.
Realistically if you're going to set up your own controls for it you just need to set up your own control layout for it.
Once you figure out all the controls you're going to use set them on the table and look at them and look at the cabinet and decide where you would put them to make it the easiest to wire and route wiring.
