Syil Spindle Still No Bueno -
Results 1 to 15 of 15
Thread: Syil Spindle Still No Bueno -
    Default Syil Spindle Still No Bueno -
    Hey All,
    I'm at my wits end with this Syil X4. I've had the spindle board rebuilt, still no movement. Vid here on where I'm at:
    At this point I'd be happy to replace the spindle control (and motor if necessary) Anyone PLEASE!!! Help!
    Anything I haven't tried with my current set up?
    Anyone who has replaced all the guts in your Syil X4?
    Please hook a brother up
    Thanks,
    CE
    Mar 2017
    Default Re: Syil Spindle Still No Bueno -
    duplicate post
    Mar 2017
    Do you have a photo of the controller card?
    Is it an XMT_DRIVER_1500 like this one?
    https://www.cnczone.com/forums/bench...-sx4-bldc.html
    Member neilw20's Avatar
    Jun 2007
    Pictures of PCBs so I know which of the many versions you have. I hAve most if the schematics.
    Your problem is in the big motor controller PCB.
    Can be a simple as e-stop lockout. Most wiring is failsafe so any broken wire will kill it.
    As your display and buttons work small parallel port board and front panel are good.
    Pictures please.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. THREE ways to fix things: The RIGHT way, the OTHER way, and maybe YOUR way, which is possibly a FASTER WRONG WAY!
    Neil and Maxspongebob,
    I was hoping you guys would show up! You both have tried to help me before. In fact in the last thread someone recommended the guy I sent the board to for rebuild
    Syil Spindle Still No Bueno --img_20190724_104404721-jpg
    Previous thread.
    https://www.cnczone.com/forums/syil-...ive-motor.html
    When I had everything pulled out that went to the rebuilder....
    Syil Spindle Still No Bueno --img_20190725_101411941-jpg
    If any close up shots will help I can take more pics
    Thank you!
  7. #7
    Jun 2007
    Quote Originally Posted by lockbuilder View Post
    Thank you!
    I believe your safety relay on main board won't be closing.
    If that is the case you won't have any voltage on the big electrolytics. Be careful. All this stuff is at mains potential.
    I don't have a schematic of your version.
    What is the psrtnumber(s) on all of the boards.
    Each version the idiots got from east-crystal are different because no proper specs for machine. EC don't care, 'cos they they just charge for development cycle again. The rot continues.
  8. #8
    Hey Neil,
    The big board at the bottom is:
    Honcar HBLC-1100-300H-S0018A
    Power Main Board Ver 1.0 2012.05.18
    The little board at the top is:
    Tonman PCF12171 Rev. 1.1
    Thank you!
    Chris E.
  9. #9
    Oh and the A is in parens.......
    Honcar HBLC-1100-300H-S0018(A)
    sorry,
    CE
  10. #10
    Jun 2007
    Sorry. Don't recognize any of those numbers.
    Try this: Closest I could find. Look at page 41. Get the Estop wiring correct.
    Ref:
    https://manualzz.com/doc/6958602/x4-plus---syil-america-bench-top-cnc-mills
    Attached Files Attached Files
  11. #11
    Member Stifffy's Avatar
    Feb 2020
    Quote Originally Posted by neilw20 View Post
    Ref:
    Hey mate could you PM me please. I tried to PM you but it won't let me. Just have a few questions I think you'd be able to help me with.
    Thanks.
    Sent from my Pixel 3 using Tapatalk
  12. #12
    Jun 2007
    Quote Originally Posted by Stifffy View Post
    Thanks.
    Your pm box must be full. It blocked my send.
    neilw21 at y7mail • com
  13. #13
    Feb 2020
    Emailed you mate
  14. #14
    Member anime2485's Avatar
    Jun 2019
    Can you guys please share the solution if one was found? I have an X4 style machine but it is older and slightly different but I can't get MACH3 to control the spindle either. Thanks!
  15. #15
    Mar 2017
    Quote Originally Posted by anime2485 View Post
    What are the identifying marks on your spindle controller?
    Look here for my solution. https://www.cnczone.com/forums/bench...-sx4-bldc.html
