OK solved it, thanks for everyones help and inputI have recently acquired a used Syil X5 speedmaster. I've got it working, mostly, Utilizing Mach3 with a smoothstepper. I have set all the home pins and dirs up in Mach3 and when I do a 'Reference All Home' the x and y home perfect but the z axis never moves.
I'd like to know where the z axis limit switch is located so I can check, e.g. clean, voltage check and etc. I've searched high and low on the web but nothing show the z axis. Syil is not much help either.
FYI in Mach3 the outline around the x and y zero buttons are green while the z zero show red. My thinking that Mach3 is not getting a signal from the z axis limit switch, if there is even one.
