Syil X3
Results 1 to 6 of 6
Thread: Syil X3
    Mar 2018
    United Kingdom
    Default Syil X3
    Is there anyone who can advise on a spindle control board on a X3, Neil who used to be on this site is no longer around so any help would be apriciated
    Mike
    Member neilw20's Avatar
    Jun 2007
    Default Re: Syil X3
    Still here. You have s problem?
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. THREE ways to fix things: The RIGHT way, the OTHER way, and maybe YOUR way, which is possibly a FASTER WRONG WAY!
    Mar 2018
    United Kingdom
    Default Re: Syil X3
    Hi Neil
    Tried to conntact you earlier in the year but no reply so assumed you were not around, but thankfully I was wrong, as you are the only one who understands the X3 mill.
    Problem is no spindle power, the front panel readout not lit, no clunk when turn on. As there has been many problems with Syil electronics I am thinking of ditching the existing board.
    Thoughts are powering motor via VFD controled by speed card in turn by Mach3, so have Mach3 working as usual?
    Any thoughts or advice? if you want to comunicate directly e-mail palmermichael[at]talktalk.net
    Regards
    Mike
    Jun 2007
    Default Re: Syil X3
    Hi Mike.
    Can you take some photos of the main board so I know which version you have. Do you gave schematics?
    Do not remove front panel with power on. The magic smoke will escape, then make sure the quill us all the way down so you don't damage anything.
    No need to access front panel yet.
    No clunk?
    Means no power to drivers.
    Can be:
    Emergency stop button. Do you use it much? Will kill main relay.
    First off, with power unplugged, tug each wire on connectors.
    What is your level of electronic experience? Multimeter.
    Mar 2018
    United Kingdom
    Default Re: Syil X3
    Neil
    To clarify the problem it is only the spindle that has stopped working all steepers work ok, I just turned on and no readout on front panel, I did not use e-stop. I have checked all connections as aware of bad crimps
    I am resonably ok with electronics yes I have a mutimeter, here is pic of board
    Mike
    Attached Thumbnails Attached Thumbnails Syil X3-p1070255-jpg
    Jun 2007
    Default Re: Syil X3
    Hi Mike.
    I have emailed PDF. Too large to attache! Grrr.
    just updated known errors. Navigate with bookmarks is best. All the information I have, in one place. Enjoy
    Neil
Syil X3
Syil X3
Syil X3
