Need Help! Non responsive syil x4 Mach3 help required
Results 1 to 8 of 8
Thread: Non responsive syil x4 Mach3 help required
    Member IhateDoug's Avatar
    Aug 2019
    Default Non responsive syil x4 Mach3 help required
    Noob needing a hand to trouble shoot what’s wrong with my machine.
    Info
    Syil x4
    Mach 3
    Was working fine up until moving it. Since reconnecting it to the pc - the pc has no control what so ever, as if the the cords not connected.
    I have
    - Checked all boards have power with a multi meter
    -checked the ports configured
    -checked the parallel cable is plugged in, checked continuity of cable and replaced the cable
    -replaced the pc (was on it way out anyway)
    -I jumped the COM and FWD pins on the inverter and the spindle starts (sunfar E300)
    -checked the diagnostics screen for life and no limit switch’s show, e-stop doesn’t show, is literally as if the machine is not plugged into the pc
    -Just ran the “config check” in Mach3 and seems “output 7” is configured wrong?
    Have read through a heap of threads but am really quiet clueless where to start looking, any input would be greatly appreciated
    Non responsive syil x4 Mach3 help required-img_0013-jpgNon responsive syil x4 Mach3 help required-img_0014-jpgNon responsive syil x4 Mach3 help required-img_0015-jpgNon responsive syil x4 Mach3 help required-img_0016-jpgNon responsive syil x4 Mach3 help required-img_0017-jpgNon responsive syil x4 Mach3 help required-img_0021-jpgNon responsive syil x4 Mach3 help required-09e95edb-2126-4f6c-beea-795c6eea629a-jpgNon responsive syil x4 Mach3 help required-img_0032-jpg
    Member awerby's Avatar
    Apr 2004
    Default Re: Non responsive syil x4 Mach3 help required
    My guess is that you replaced your PC with one that didn't have a working EPP parallel port. You might check BIOS to see if it's turned off, but more likely it just doesn't have a parallel port that's suitable for machine control. If the previous PC still works, put it back in the system and see if things improve. Meanwhile, keep an eye out for another old PC with a parallel port, or switch to a USB or ethernet interface.
    Aug 2019
    Quote Originally Posted by awerby View Post
    Same problem when connected to the original.
    It’s enabled in the new one alsoNon responsive syil x4 Mach3 help required-img_0011-jpg
    Apr 2004
    Were the motors energized when you unplugged everything to move it? If so, that could have blown your drivers.
    Aug 2019
    Not 100% sure (was 8months ago) but is a fair chance. How would I test that/what would I need to replace?
    -thanks for the input also really appreciate it
    Apr 2004
    If you unplug the motors when they are powered up, that creates a spark which can kill the drivers. If that's what happened, you probably need to replace them. If you've got a spare one, you can try it and see if the axis you install it in comes back to life. Just make sure to do that before applying power to the system, and to shut everything down (and wait for the caps to drain) before unplugging anything.
  7. #7
    Aug 2019
    Sorry my knowledge is pretty limited - I farm oysters, bought it as a hobby type thing to play around with and bring my useless inventions to life.
    By driver do you mean theses black boxes?
  8. #8
    Aug 2019
    Just noticed that the machine doesn’t have the charge pump connected - has jumper between pin 2-3. Could this have something to do with it?
    Attached Thumbnails Attached Thumbnails Non responsive syil x4 Mach3 help required-img_0105-jpg
