Need Help! Blown Syil spindel controller
Results 1 to 2 of 2
Thread: Blown Syil spindel controller
    Nov 2009
    switzerland
    Default Blown Syil spindel controller
    Hello
    I have a blown Syil Xp5 spindel controller. I want now to replace the controller with a servo controller and a new motor with higher torque.
    In order to have the same functionality (rpm, spindel start, stop, cc, cl) I have to interface the existing signal. I do not understand all of the function
    of the syil board.
    Conector on blown board: 15V | 5V | NC|NC|DIR|PWM|GND in some manual (www.hipoo.cn) on the net I found for some simlar
    card: 15V|5V|TAP|S/P| F/R|PWM|GND
    TAP: external electric low level, the tapping function is available. When motor runinng at 500rpm/m, high power or open, tapping function invalid.
    I do not understand that!
    S/P: Start/Stop in the shutdown state to a negative pulse start, turned down in a negative pulse stopped, a negative pulse every time a status change.
    I don't understand. What happens?
    F/R: is clear should be 0.6V or 0V.
    PWM: Have to convert that to 0-10V (What's best?)
    could anybody help?
    Nov 2013
    Default Re: Blown Syil spindel controller
    most AC servos and drives hav a velocity mode. It allows you to apply an analogue -10v-+10V signal
    and the servo motor will run at a given speed.
    You would have to make a simple circuit to implement the +10-10 signal, +10 is FWD and -10 is REV.
    https://store.dmm-tech.com/
    Craig
