- Syil X4 Pneumatic Drawbar
Re: Syil X4 Pneumatic Drawbar
That is a very neat looking setup. What is the price of this?
Would love to fit something like this to my X4+
Matt
power draw bar kit = $550
pan cake Cylinder (you order, I have part number) = $175 (full retail)
1/2 Aluminum scrap = CHEAP
3/8 ready rod = $10.00
2 way 5 port switch (you order, I have sample part number) = $25.00
Air lines and fittings (you supply)
1/4 / 20 bolts (you supply)
set screws (you supply)
one spring pin
I have all pictures of the process. You have to fabricate the install brackets yourself, as I did not make any drawings. Very simple fabrication, took me couple evenings to complete.
If you get the pan cake cylinder off ebay and switch you can build this cheaper than full retail around 700 cnd all in.
Hi
Thanks for the update. So I am clear, what is in the drawbar kit?
Matt
- You may not post replies
- You may not edit your posts
Forum Rules
