Syil X4+ Gas Strut
Results 1 to 6 of 6
Thread: Syil X4+ Gas Strut
    Oct 2013
    United Kingdom
    Default Syil X4+ Gas Strut
    Whilst stripping my machine for cleaning, I took the gas strut off and noticed it was more like a slide whistle with zero resistance!!
    Anyone replaced one on their machine? The label on my strut is badly worn and torn. Not sure if it would help if I had any figures from it.
    I could try a generic one BUT I really don't know what force is required. Anyone got any suggestions?
    Matt
    Member jalessi's Avatar
    Feb 2007
    Default Re: Syil X4+ Gas Strut
    Matt,
    After you measure the original strut length checkout the McMaster-Carr part number 4138T63 with 100 pound extension force, it may be a good substitute.
    Have a most awesome day!
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Oct 2013
    United Kingdom
    Thanks Jeff,
    It looks like the head unit is approx 30kgs (66lbs) Do you think I should consider the lower spec strut (50lbs)?
    In the UK, they seem to be calibrated in Newtons - and so 30kgs equates to 300N.
    Will have a look at the McMaster parts......
    Matt
    Member neilw20's Avatar
    Jun 2007
    Make sure the new strut is mounted skinny shaft downwards, so that the seals remain covered in oil.
    Original factory install was wrong way up.
    You can get a longer strut to increase the travel of the head.
    http://www.cnczone.com/forums/syil-p...ml#post1199056
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. THREE ways to fix things: The RIGHT way, the OTHER way, and maybe YOUR way, which is possibly a FASTER WRONG WAY!
    Oct 2013
    United Kingdom
    Thanks neilw20.
    I read somewhere about them being the wrong way round! I have one arriving tomorrow and will ensure it is correctly installed.
    Matt
    Oct 2013
    United Kingdom
    I can now confirm that the 400N gas strut seems to work OK. Now onto other bits of the machine!
    Matt
Syil X4+ Gas Strut
Syil X4+ Gas Strut
