- Star VNC 32 Overtravel in middle of travel
The X axis is alarming OT002 in the middle of the travel. It is a Fanuc 10. Any help is appreciated,.
Re: Star VNC 32 Overtravel in middle of travel
pfmn95492,
You're sure your parameters for OT are set correctly?
Two potential ways on a 10 control depending on sys software. 1) Hold "P" and "CAN" while powering up. You'll get no confirmation that it did anything until you move it and have no OT alarms.
2) Need to get into IPL menu to shut off OT before Zero Return. Hold (-) and (.) while powering up and you will have the IPL menu. Look for "SETTINGS" (menu item 4??) , say "YES", exit and power up.
Check your reference switches
Apparently the X axis is slowly sinking when turned off. That's probably why it loses its position. Does anyone have any ideas what we'll need to fix to keep it from moving when off?
- You may not post replies
- You may not edit your posts
Forum Rules
