New Machine Build Stirling engine with rhombic drive 84 ccm 108 Watt on first test run
Results 1 to 1 of 1
Thread: Stirling engine with rhombic drive 84 ccm 108 Watt on first test run
    Mar 2016
    Germany
    Default Stirling engine with rhombic drive 84 ccm 108 Watt on first test run
    I want to show you my new Stirling engine with 84 ccm swept volume scaled of the GPU 3 using the methods of Dr. Allan Organ.
    It has a rhombic drive, slotted heat exchangers and a ss-foil regenerator (wire mesh regenerator is in building stage).
    First test runs gave 108 Watts at 7 bar air pressure but I plan many modifications to improve performance significantly.
    A small Youtube video shows it in operation an also a few scenes from the workshop:
    A few photos:
    I am always happy for comments and suggestions.
    Thanks for your interest and greetings from Germany
    Ralf
    tom-rock@web.de
    Attached Thumbnails Attached Thumbnails Stirling engine with rhombic drive 84 ccm 108 Watt on first test run-1-img_4463-jpg   Stirling engine with rhombic drive 84 ccm 108 Watt on first test run-1-img_4472-jpg   Stirling engine with rhombic drive 84 ccm 108 Watt on first test run-1-img_4470-jpg
