Need Help! Allegro A6615SED stepper motor driver
Results 1 to 9 of 9
Thread: Allegro A6615SED stepper motor driver
    Jun 2009
    Serbia
    Exclamation Allegro A6615SED stepper motor driver
    Hello All,
    I scrapped a board from Epson printer which has an IC named A6615SED (probably made by Allegro - has an "A" logo). But I cannot find a datasheet for it. Can anyone help me with this IC? I want to use board and motors for my hobby project.
    Thank you.
    Feb 2010
    Italy
    Hello, have you find it? I also need this datasheet. I was thinking to try to understand the schema beginning from the datasheet of E01A39CA, an other big Epson IC on the board, but I can't find its datasheet too.
    My board is C483 MAIN-B.
    Silvio
    Mar 2010
    Argentina
    Default Me too!
    I have actually 3 scrapped boards, one of them is A6628SEDT which apparently pin by pin compatible... I could not find any info about them... nor another Allegro similar product. It looks like A3988 has the same functionality, but not the same package... A6628 and A6615 are PLC44
    any help?
    Apr 2004
    I'm in the same boat I scraped a epson c64 printer and it has a A6615sed on it. I was looking at using as a driver. Just cant seem to find data sheets.
    Apr 2004
    I found the data sheets for the a6615sed If your intrested in the links send me a message
    Apr 2004
    Ok, between these two images you more or less have every thing you need to make a PCB for this driver. any one makes a PCB for it please post it.
    EPSON C43????? - ?????
    http://www.jqdzw.com/article/UploadPic/2010-6/2.jpg
    google chrom translater works well for the link below
    EPSON*C4X
    http://www.slwx.com.cn/bbs/UploadFil...6504081848.jpg
  7. #7
    Apr 2004
    EPSON*C4X
  8. #8
    Feb 2011
    makedoniski brod
    Hello all,
    and J search datasheet for a6615sed but J can't find ((. Berin can you send me datasheets for this step driver j realy needed. Thanks
  9. #9
    Jan 2013
    France
    Default Datasheets
    A nice wiring diagram can be found in the Epson's documentation.
    http://www.cursos.pro.br/downloads/e...42_C43_C44.pdf
    For the serial interface, I'm not sure, but here is the datasheet for a similar chip:
    http://www.allegromicro.com/en/Produ...Datasheet.ashx
