What stepper motor should I use thread - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 63 of 63
Thread: What stepper motor should I use thread
  1. #61
    Activation process Gaunt1969's Avatar
    Nov 2018
    Default Re: What stepper motor should I use thread
    I think this is the post of SWEDE'S you are referring to
    https://www.cnczone.com/forums/linea...-software.html
  2. #62
    Jun 2010
    Quote Originally Posted by mokhabarat View Post
    hello
    I read through this forum but to be honest my limited knowledge about the subject prevents me from understanding some of the terms listed and how to deal with them.
    I built a 3m by 1.8m cnc machine and had it up and running until I decided to upgrade my 700W spindle motor to a 3.5kW one complete with a VFD.
    The problem I'm facing is that my carriage now weighs about 14KG (about 31lbs) and my openbuilds NEMA23 motor cant lift the spindle anymore for Z-axis movement. X and Y axes still work fine, both are also using NEMA23s.
    The Z axis holds the spindle motor and drops it fine but cannot lift it, i can lower the spindle motor and keep it still but cannot get upward movement, when I try it just tries to spin upwards but ends up slipping downwards.
    What I want to know is if I upgrade to a NEMA34, will I be able to fix this? Do I need to upgrade my driver as well for this stepper? I'm using a 24V power supply with 36amps capacity and this driver from amazon couple onto an arduino uno.(Witbot CNC Shield Expansion Board V3.0 +UNO R3 Board for Arduino+ A4988 Stepper Motor Driver With Heatsink Kits for Arduino)
    https://www.amazon.com/Witbot-Expans...bot+cnc+shield
    Counter balance springs if on budget.?.
  3. #63
    Jan 2006
    I use a number of "tools" on my nema 23 powered Z plate, including a big heavy motor & spindle from a dead mill. I added an air cylinder to assist the Z, i can dial in the air pressure to balance the load. It has been working great for years.
