1PC Nema23 stepper motor 1.45Nm, 1.8°,76mm,6wires,1.0A 23HS8610 CNC
Results 1 to 2 of 2
Thread: 1PC Nema23 stepper motor 1.45Nm, 1.8°,76mm,6wires,1.0A 23HS8610 CNC
    Longsmotor2's Avatar
    Sep 2024
    Default 1PC Nema23 stepper motor 1.45Nm, 1.8°,76mm,6wires,1.0A 23HS8610 CNC
    23HS8610
    This item includes:
    Detailed information:
    Nema 23 stepper motor
    Step Angle:1.8°/ Step
    Rated Voltage:8.0 V
    Rated Current:1.0 A /Phase
    Phase Resistance:8.0 ohm/Phase
    Phase inductance:19 mH/Phase
    Holding Torque:1.45N.m
    Detent Torque:6.8 N.cm Max
    Rotor Torque:480 g-cm²
    Number of Wires:6
    Motor Length:76 mm
    Motor Weight:1.0kg
    Nov 2013
    Default Re: 1PC Nema23 stepper motor 1.45Nm, 1.8°,76mm,6wires,1.0A 23HS8610 CNC
    Hi
    19mH and 8 Ohm per phase??? That means a time constant of 180ms!!!
    Not much cop for CNC.
    Are you sure about those numbers???
    Craig
    - - - Updated - - -
    Hi
    Craig
