New shaft in steppermotor ?
Results 1 to 7 of 7
Thread: New shaft in steppermotor ?
    Jul 2009
    Denmark
    Default New shaft in steppermotor ?
    I need a longer shaft in my steppermotor (Nema17). How do i replace the shaft without loosing power in the motor?
    Best regards
    Poul Munch
    Member awerby's Avatar
    Apr 2004
    Default Re: New shaft in steppermotor ?
    Just extend it with a rigid coupler.
    Dec 2003
    Check out Misumi, they have a wide selection, https://us.misumi-ec.com/vona2/resul...or%20couplings
    Jul 2009
    Denmark
    Thats is not possible. I need a longer shaft to get a firm grip in the remote bearing. The shaft has round edges. This gives only 2mm contact area with the remote bearing (not shown).
    New shaft in steppermotor ?-img_1238-1-jpg
    Apr 2004
    If you pull off those pulleys first, there's plenty of room. But with that much sideways load on the shaft, it might kill the motor bearing or snap it. What are you trying to do here, exactly?
    Jul 2009
    Denmark
    As you can se on the picture, there is not much space after the last pulley, to mount the extra bearing needed for support. If i could extend the shaft by just 4mm.
  7. #7
    Nov 2013
    you cannot put a new shaft in a stepper, once you disassemble it you'll wreck the magnetics.
    I think Awerby is right if you had a longer shaft all you are doing is overloading it which will kill the stepper quick smart. You want a separate shaft with bearings at both ends and couple that
    (with a coupler) to the stepper. The stepper will not respond well to axial or radial loads.
    Craig
