Looking for help with TB6560 stepper motor driver.
Results 1 to 8 of 8
Thread: Looking for help with TB6560 stepper motor driver.
    Apr 2007
    Israel
    Default Looking for help with TB6560 stepper motor driver.
    Hi, I hope that there are here people that have experience with TB6560 (Chinese) 3 axis stepper motor controller board. I would like to set up since I want to learn and inquire some experience to a field that is new to me. now, my first dilemma is about the E-stop and limit switches. from my experience with machines, the E-stop is a NC switch that connects the E-stop point to GND and enables the machine to operate. once it's pushed - it opens and disconnect the GND and disables the machine. is it the same here?
    Attached - picture of the board.
    Thanx for your help.
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Default Re: Looking for help with TB6560 stepper motor driver.
    Hi Amron - no picture - Pter
    Apr 2007
    Israel
    Quote Originally Posted by peteeng View Post
    You're right, sorry. here it is (I hope...)
    Attached Thumbnails Attached Thumbnails Looking for help with TB6560 stepper motor driver.-tb6560-jpg
    Member Vlod's Avatar
    Apr 2022
    It’s programmable in Mach3/4 software. You can use NC or NO switches, most people prefer NC.
    It’s whatever hardware you use.
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    East Tennessee
    Some information about a similar board here:
    https://reprap.org/wiki/4_Axis_TB656...ard_Controller
    Note they are not exactly the same, but it may still be useful as they seem to share much of the design.
    Apr 2007
    Israel
    Quote Originally Posted by Vlod View Post
    Do you know where I can find information how to (to which points) connect the E-stop and the limit switches? my search on the web yield various versions. on some it says that they should be connected to the DB15 port while others - to the DB25 port. RaderSidetrack was kind to post a link to a 4 axis version, which I believe is also different from the 3 axis board that I have. as I mentioned, I never dealt with it before and I really don't wish to cause damage by creating shortcircuits.
  7. #7
    Dec 2012
    Netherlands
    Attached you will find the manual that I found. It looks that the small four pin connector is the one you are looking for.
    You have to configure it in the software
    Attached Thumbnails Attached Thumbnails Looking for help with TB6560 stepper motor driver.-3-axis-tb6560-3-5a-stepper-motor
  8. #8
    Apr 2007
    Israel
    Thanx. I'll look into it.
