Need Help! D86 Stepper Motor driver (Step Servo) Ex+ EX- Usage or link to manual
Results 1 to 4 of 4
Thread: D86 Stepper Motor driver (Step Servo) Ex+ EX- Usage or link to manual
    Member Abhik's Avatar
    Jun 2022
    Default D86 Stepper Motor driver (Step Servo) Ex+ EX- Usage or link to manual
    I am retrofitting a Brazilian milling machine with ball screw leads and CNC controlled stepper motors, mechanics are finalized and OK. But I can not complete connecting the D86 Stepper Motor driver (Step Servo), which is a kind of hybrid stepper/servo driver (stepper motors have encoders) because I can not locate a D86 manual (PDF) Already 6 hours googling.
    Most connection terminals are customary like the more common HBS86H driver, but this driver includes two extra connections labeled "EX+" and "EX-" which I can not account what are they for. So I do not want to start the system, with just this terminals "un-connected"
    Can any one leadme to the D(& manual or to what those terminals are used for?
    It´´s been almost a week looking for It, but I can not find an answer.
    Thanks in advance
    Jan 2018
    United Kingdom
    Quote Originally Posted by Abhik View Post
    Thanks in advance
    Do you have an image of it?. May be an alternative manufacturer model to compare.
    Jun 2022
    Default Re: D86 Stepper Motor driver (Step Servo) Ex+ EX- Usage or link to manual
    Yes I have, (I am new to the forum, I hope I can attach the image,,,)
    Although my red marking on the terminals obscure the detail, those terminals have their own 2 position terminal conector, so I guess they are probably not not part of "typical Stepper motor connections".
    Following your thought, I did find a hybrid closed loop steeper motor driver with those terminals (Hanpose cl57) They are labeled as "Signal Outputs", so I would like to infiere they will not prevent the driver operation, but at my age being an engineer, I have learned to "Do not make suppositions" (It does apply equally to interpersonal situations). Do your homework.
    I am attaching an image of that driver.
    Again, no luck to find it´s manual. There is a Leadshine CL57 Closed-loop stepper driver, but that one do not include those terminals...
    No luck also googling "servo driver ex+/ex- signal output"...
    I appreciate your interest....
    Attached Thumbnails Attached Thumbnails D86 Stepper Motor driver (Step Servo) Ex+ EX- Usage or link to manual-captura-de-pantalla-2022-06-18-020033-a   D86 Stepper Motor driver (Step Servo) Ex+ EX- Usage or link to manual-captura-de-pantalla-2022-06-18-010827-a
    Jan 2018
    United Kingdom
    Looks to me like it's to do with a motor brake. Connections by different name.
    https://www.omc-stepperonline.com/cl...er-motor-cl57t
    The only other possible extra connections on these drives is 'Pend'
