You want to run those motors on at least 48vdc to the drivers.
Change to DM556T and up your voltage.
Personally I would run them using DM860T and 60+vdc. It would fly and they are good drivers. Those motors are likely to be high inductance so the bigger the driver and higher the voltage the better they will work.
Closed loop drivers won't work with open loop steppers.
