add stepper motor
Results 1 to 2 of 2
Thread: add stepper motor
    Member IKandyLLC's Avatar
    Nov 2021
    Default add stepper motor
    on my 3d printer i was able to piggyback a stepper on the z axis for better resolution. thets say you have a 3 axis board and need a dual steeper setup to control both sides of the gantry, can you do the same and run two longs as they didnt max the v/a?
    Nov 2008
    Default Re: add stepper motor
    Not sure what two longs means but I recommend you search images for: wire two steppers serially
    MarkLiu's Avatar
    Jan 2022
    stepperonline has a lot of suitable inexpensive stepper motors.Some customized services are also available.
    https://www.omc-stepperonline.com/hybrid-stepper-motor/
add stepper motor
add stepper motor
