Given your very modest speed requirements, just using duplicates of your other machine motors and controls should work fine.
Hello,
I am looking to build my own CNC wood router. I currently own a used one that I purchased off someone else who built it. It isn't large enough and I don't particularly want to modify it since it will work for some of my smaller projects.
The current one uses I believe NEMA23 stepper motors for a 5 ft. (X-axis - 1 Stepper) x 6 ft. (Y-axis - 2 Stepper) x 6 in. (Z-axis - 1 Stepper) cut area using a palm router.
I have the mechanical side of the project locked down for the new one, but I need to select the stepper motors and the other electronics that will be compatible.
My General Specs:
Overall dimensions:
X = 6 ft. (overall) (1 stepper motor)
Y = 10 ft. (overall) (2 stepper motor)
Z = about 1 ft. (milling height) (1 stepper motor)
Router weight = 10 lbs. (per online spec)
Gantry = 15 - 20 lbs. prior to stepper motors and router (estimated, it may be less)
max required in / min. = 100 in. / min.
Average milling speed X - Y axis = 40 - 60 in / min.
Rack and gear combo for X and Y axis.
Screw for Z axis.
Any recommendations?
Jim Dawson
Sandy, Oregon, USA
Thanks for the quick response Jim.
The current one uses a USB to serial converter. Is there a current control board that can go direct from USB?
A quick search turned up this one. https://www.automationtechnologiesin...ntroller-mk3-4
I don't really know anything about these boards. But you can read all about them here https://www.cnczone.com/forums/planetcnc/
Jim Dawson
Sandy, Oregon, USA
I would prefer to use an ethernet smoothstepper or UC400eth for controller. Usb can bring up noise issues if using vfd spindles.
For steppers I would use nema24 566oz motors.
For drivers I would use DM860T.
I would run them on 60v power supplies.
I have this type of setup on my mill and it flies. After trying so many different steppers/drivers/voltage combinations this is where I settled.
I've tested it as far as 130ipm with almost full acceleration and it never missed.
I'll look into some links later.
Following my previous post.
Motor:
Best budget motor but small size shaft.
https://www.automationtechnologiesin...l23h2100-56-4b
2.2mh iinductance, 1/4" shaft.
Next option slightly thicker shaft:
https://www.automationtechnologiesin...flat-570-oz-in
https://www.automationtechnologiesin...00-50-4b-cable
2.5mh iind, 3/8th" shaft.
Next oiption metric shaft:
https://www.omc-stepperonline.com/ne...s39-4204d.html
3mh ind, 8mm shaft.
The last one is exact same spec as my ones (I have different brand). Using 60v on a driver compensates for the higher inductance value. All three are perfectly fine at that voltage though.
Driver:
https://www.omc-stepperonline.com/di...or-dm860t.html
Power supply:
https://www.aliexpress.com/item/4000...c00VlWAs0&mp=1
You can choose input/output voltages to suit needs.
I have a 60v out / 220v in.
There are other brands/sellers to browse through too.
The above is if you are not looking into closed loop units.
Or if looking at proper servo systems like:
https://www.aliexpress.com/item/3304...16109932%22%7D
