Need Help! Determining correct wires from stepper motor
Results 1 to 2 of 2
Thread: Determining correct wires from stepper motor
    Mar 2016
    Default Determining correct wires from stepper motor
    Is it possible to determine the wires from stepper motor A+ A- and B+ B- using a multimeter ? If so HOW ! thanks
    Nov 2013
    Default Re: Determining correct wires from stepper motor
    there will be a low resistance, several Ohms or less between A+ and A-, and also between B+ and B-, but open circuit between any A and any B.
    As for the difference between + or -...who cares. Just wire it up and then swap just one winding if the stepper is going in the wrong direction.
    Craig
