stepper driver
Results 1 to 3 of 3
Thread: stepper driver
    Jan 2018
    United Kingdom
    Default Re: stepper driver
    This one?
    https://www.aliexpress.com/item/32544858351.html
    https://www.chinahao.com/product/524730259070/
    https://www.mpja.com/Stepper-Motor-D...fo/18727%20MS/
    CW1108 stepping Motor Driver - Chawing Electronics
    If the above is so, then...........
    It looks to me that any driver that works off 110-220vac such as the Leadshine DM2282 should be a compatible alternative:
    http://www.leadshine.com/uploadfile/down/dm2282d.pdf
    Just double check the specifications match yours first, but it looks like it does to me.
    You can use this one to replace it, KL-2283 8.3 A Digital Bipolar Stepper Motor Driver, AC 80-220VAC – 32 bit DSP Based
    https://www.automationtechnologiesin...ivers/kl-22083
stepper driver
stepper driver
stepper driver
