How can I run Nema23 @ 2or3 rpm
Results 1 to 4 of 4
Thread: How can I run Nema23 @ 2or3 rpm
    Mar 2017
    Default How can I run Nema23 @ 2or3 rpm
    I have a spare Nema 23 & M335 driver which I would like to be able to run at very low variable speeds for a non CNC project.
    Is there an easy way to achieve this? Potentiometer maybe? Or am I being naively hopeful.
    Dec 2013
    Default Re: How can I run Nema23 @ 2or3 rpm
    Jim Dawson
    Sandy, Oregon, USA
    Member CitizenOfDreams's Avatar
    Nov 2012
    Here is another one that will work:
    https://www.ebay.com/itm/294216615395
    Problem is, these boards may have too wide of a speed range for you. At the lowest setting, the speed will change from 1.5RPM to 45RPM (80Hz to 2400Hz).
    Mar 2017
    Thanks Jim
