Consider using a timing belt to drive the lower wheels only. Let the upper wheels freewheel, held down by adjustable spring pressure and use a lever system to raise them for loading the tube.
Here is something similar that I did to feed a flat strip
https://www.cnczone.com/forums/attac...d=461300&stc=1
