Need Help! Stepper motor sizing based on load travel time and distance
Results 1 to 3 of 3
Thread: Stepper motor sizing based on load travel time and distance
    dpressm's Avatar
    Sep 2020
    Default Stepper motor sizing based on load travel time and distance
    OK I know people hate seeing the same topics again and again but ...
    Hello, I am a software guy who is new to using stepper motors. Basically I have built a large moving bookcase door that rolls back and forth. I have connected it to steel cables and pulleys into the attic where I want to place a stepper motor and gearing to open and close the door. I had imagined using a chain drive attached to the steel cables. Size is not a problem as all of the mechanics are up in the attic.
    I am not sure where to start and do not expect you to all my work for me but could you at least point me in the right direction?
    Here is what the operational parameters are:
    Distance of travel: 40 inches
    Force to roll Bookcase: 25 lbs (measured by pushing on a scale against the bookcase) Actually it was probably closer to 30 to get movement started and 18 while moving.
    Expected time of Travel: about 3 seconds maybe more
    Frequency of usage: No more than 45 times a day
    Why a stepper? This "Bookcase" will actually contain some fairly fragile artwork - sculptures etc. so i want to be able to accellerate and decelerate smoothly. I plan to use ultrasonic distance measurers to confirm the position as there is some slack in the cables and I would expect some stretch. Obviously exact positionoing is really only important at the beginning and end of the motion. I will also use infrared motion detectors to check for obstacles (either stationary or moving - think scurring dogs trying to beat the door).
    I can gear the motor as needed as there is no problem with space.
    I plan to use either an arduino or a rasberry pi to control the door.
    I would prefer the motor to be unbraked (?) so it can be moved manually if needed.
    I have attached a picture of the 8 ft tall bookcase (before the finish moldings and shelf lighting were installed) and two pictures of the mechanism as it attaches to the bookcase and guide track and of the cables going up to the attic. There is a second guidebar and attachment at the bottom as well as cables to pull the bookcase both open and shut.
    Thank You VERY much!
    Attached Thumbnails Attached Thumbnails Stepper motor sizing based on load travel time and distance-20200916_144712_resized-jpg   Stepper motor sizing based on load travel time and distance-20200916_144155_resized-jpg   Stepper motor sizing based on load travel time and distance-20200916_144722_resized-jpg
    May 2015
    Default Re: Stepper motor sizing based on load travel time and distance
    Yours is more of an industrial problem as opposed to CNC, so this might be a good starting point
    https://www.machinedesign.com/motors...-linear-motion
    Don't forget to allow for acceleration and deceleration in your application. it doe snot just happen.
    Rod Webster
    www.vmn.com.au
    Aug 2015
    I think a nema 34 will suit ok for all this forces , or a nema 23 with a reducer .
