Need Help! First time CNC project
Results 1 to 4 of 4
Thread: First time CNC project
    Member damorus's Avatar
    Aug 2020
    Default First time CNC project
    Not sure which forum to post this in, so if this is the wrong one, I will apologize in advance and hope you will move it to the correct forum.
    I am completely new to this CNC / Mach3 / Breakout board / Stepper motor world, so please take it easy on me
    My first project is going to be a CNC plasma cutter table, but my problem is way more basic.
    I can't seem to get the stepper motors to rotate.
    Here is my setup:
    https://www.cnczone.com/forums/attac...1&d=1597826274
    I am trying with just one stepper motor for testing purpose.
    I am using a C10 breakout board, but I also have a C11G breakout board that gives me the same result.
    The problem is a simple as; Nothing happens on the breakout board when I drive the motor in Mach3.
    I have set up the ports and pins correctly in Mach3. I have set the PUL to pin 5 (red wire) and DIR to pin 4 (Yellow wire)
    I have used a UC100 USB controller with the same result and I can see in Mach3 that pin 4 is activated when I drive the X axis a certain way. However, the voltage on pin 4 is 0, never 5V
    From Mach3s POV everything is fine, the X axis is running fine, however nothing happens on the board.
    How can I troubleshoot this?
    Is it the 5V power supply to the board?
    I use a USB charger, found an old UBS wire and cut it open and found the 5V wires.
    I have tried with Win 10 Laptop (UC100), Win 7 laptop (UC100) and Win xp (Parallell port) stationary PC, all with the same result.
    Hopefully you can help me
    Br
    Joachim
    Attached Thumbnails Attached Thumbnails First time CNC project-img_20200819_101403-jpg   First time CNC project-img_20200819_101326-jpg
    Member routalot's Avatar
    Dec 2003
    Default Re: First time CNC project
    My guess is that the problem is with the cables from the drives to the steppers and you may have one pair incorrectly connected.Do you have the means of checking which pairs of the motor connections are on the same circuit?I had a similar problem getting my steppers to work with LinuxCNC.
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Hi Damoros - Check you are getting voltage out of the phone charger. Phone chargers have circuits that shut down the charger if the current is low ie the phone is charged or disconnected. Since the charger is expecting amps and the control circuit uses very small current this maybe the issue. Other wise check, check and more checking... Peter
    Aug 2020
    Thank you both for your reply! I actually found the problem
    I needed to connect the enable terminal (ENA) to the 5V terminal..
    Did that and a green "active" LED lighted up on the board and the motors worked perfetly
    Again, thank you for you help! Really appreaciate it! <3
    Br
    Joachim
