Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z
  1. #21
    Smile Re: Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z
    hey,
    i finally finished my upgrade. Now i need to trim the surface. from 0.085 to 0.000 any tool recommented to this job.
    The material i used to do this project:
    1/2 steel plate 19x30
    18, M6 hex screws
    Quarter inch finish plywood
    M6 inserts.
    Attached Thumbnails Attached Thumbnails Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z-img_0669-jpg   Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z-img_0670-jpg   Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z-img_0671-jpg   Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z-img_0672-jpg
    Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z-img_0673-jpg
  2. #22
    Default Re: Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z
    PS.
    i guess i can't use this tool, Unless i trim the shaft down to 12mm, to make fit ER20 collet #12.
    Any ideas
    Attached Thumbnails Attached Thumbnails Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z-img_0674-jpg   Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z-img_0675-jpg
  3. #23
    Member CitizenOfDreams's Avatar
    Nov 2012
    Quote Originally Posted by akihiko View Post
    I very much doubt you could use this tool even if you manage to fit it in the collet. The spindle would not have enough torque, and the machine itself would not have enough rigidity. Something like 1/2" cutter (or smaller) would be more realistic.
  4. #24
    Mar 2003
    Shelby Township
    Surfacing that plywood is not going to result in a very good finish.
    You'd be better off adding some MDF on top and surfacing that.
    Just get a cheap bit like this.
    https://www.amazon.com/Yonico-14973-...480408&sr=8-28
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  5. #25
    hey,
    I'm Thinking of Upgrading my Stepper Motor's to --> Closed Loop Stepper Motor.
    I'm looking at two differen Closed Loop Stepper Motor.
    1. STEPPERONLINE 1 Axis Closed Loop Stepper Motor Kit 2.0Nm 1000CPR Nema 23 Closed Loop Stepper Motor+0-7A 24-50VDC Stepper Driver+2 Extension Cable $106.99
    OR
    2. RATTM MOTOR, Nema23 3.0Nm Closed Loop Stepper Servo Motor 88mm 5A+HSS60 Hybrid Driver CNC Kit $145.99
    Which one would will be a good choice?
    Would appreciate a good feedback.
    thanks.
    Attached Thumbnails Attached Thumbnails Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z-hss60-jpg   Help with tuning Stepper motor& Drive on UCCNC AXIS X,Y,Z-cl57y-jpg
  6. #26
    Just fine out that (STEPPERONLINE 1 Axis Closed Loop Stepper Motor Kit 2.0Nm 1000CPR Nema 23 Closed Loop Stepper Motor+0-7A 24-50VDC Stepper Driver+2 Extension Cable)
    It only a 2.0 283.28 Torque(oz.in)
    And the next one up it a (E Series Nema 24 Closed Loop Stepper Motor 4.0 Nm(566.56oz.in) Encoder 1000CPR) Which is better. for $120.00
