Need Help! will it work ?
Results 1 to 5 of 5
Thread: will it work ?
    Member abhi163's Avatar
    Aug 2020
    Default will it work ?
    Dec 2013
    Default Re: will it work ?
    That's a lot of power supply. But the voltage is a bit low for that drive to get any performance out of the stepper motor. But no, it won't blow anything up if correctly wired. I recommend a fuse between the power supply and the drive, maybe a 6 Amp fast blow because the drive is rated at 5 Amp
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2020
    yes driver is rated at 5A but many places I read that driver takes only what it needs from the power supply
    I don't know if it's true or not
    Dec 2013
    Yes, that is correct. It is normally good practice to add a fuse ahead of the drive to protect the drive, especially when the power supply is capable of turning that drive into a flaming puddle of goo if there were a short or something. 133 Amps is a lot of available current.
    Jim Dawson
    Sandy, Oregon, USA
    Aug 2020
    update
    I tried it with fuse
    its correct "driver only takes how much it wants from the power supply "
will it work ?
will it work ?
will it work ?
