Hybrid stepper motor.
Results 1 to 8 of 8
Thread: Hybrid stepper motor.
    Member Pugman1's Avatar
    Jun 2020
    Default Hybrid stepper motor.
    Hi, I wonder if anyone out there can help me. I need to swap out the stepper motor on my z axis. It’s a little nema 23. I would like to replace something with a little more torque. Would it be possible to use a hybrid motor just on the z axis alone. I am using a CS-Labs CSM10/IP-M motion controller and Mach3 .thanks
    Default Re: Hybrid stepper motor.
    Nov 2013
    no doubt there are many high torque 23 size motors but they also have high inductance and you need to avoid them.
    All steppers lose torque the faster they go. Winding inductance is the primary measure of how bad that torque degradation will be.
    A 6mH motor might have as little as 5-10% of its rated holding torque at 1000rpm whereas a 1-1.5mH motor might have as much as 40-50%
    at 1000rpm.
    By all means find a motor with more torque but reject anything over 2mH or your new motor will start losing steps or stalling at speed.
    The classic way to overcome winding inductance is to use the highest voltage driver and power supply you can find. At the current time the
    market leaders are 80VDC capable.......you should aim for 80VDC drivers and supply.
    Craig
    Jun 2020
    Thanks for the reply’s
    Jan 2018
    United Kingdom
    Quote Originally Posted by Pugman1 View Post
    Finding something high torque (say 425oz- 570oz) with an inductance of less than 2.5mh is pretty much impossible.
    My 570oz nema23 from the uk are 3mh (the uk has crap!). Importing the Automation tech ones would have cost too much.
    https://www.automationtechnologiesin...3h2100-50-4bm/
    To counteract my inductance I run them on 60Vdc with 80vmax drivers. They run awesome and are quiet.
    Anything above 2mh run on 60Vdc it makes a big difference but. Go no more than an inductance of 3mh.
    Member v0dka's Avatar
    Dec 2019
    In the scope of this discussion, I've a serious dilema :
    I'm building a Router CNC, and planned to buy 4 NEMA34 closed loop steppers ... I targetted this model : https://www.befr.ebay.be/itm/1Axis-N...MAAOSwTm9dUqyN
    5Nm Torque and 2mH inductance
    But at this moment, there are sale on the 9Nm and the 12Nm version:
    for the same price, i can get the 12Nm version but has and inductance of 8.4mH, or for 10% less I can get the 9Nm version with an inductance of 4.2Nm
    In my design, i expected 5Nm ok for my need (two steppers config for the Y, one for the X and one for the Z)
    PS: expected power supply are 350W 60VDC (one per stepper)
    What would you advice ?
  7. #7
    Nov 2013
    I personally would get the low inductance motor.
    May I suggest that you compare, preferably overlay the three speed/torque diagrams and I'll bet you that the 5Nm motor
    has more torque at 1000 rpm than either of the 'apparently' stronger motors, that's what low inductance gives you.
    I think your power supply, at one per stepper will be more than adequate, but if you can get 72VDC or 80VDC assuming your drivers
    are rated to 80VDC they are preferred. It gives you more top end speed.
    Craig
  8. #8
    Dec 2019
    Craig
    Actually, the drivers are rated to 100VDC ... but it is quite hard to find such power supply
