Hello to all of you gurus again.... I was hoping that by now some would have shed some light here... but understand that me post is all over the place... and that is how I feel.
I think what I really wanted to ask is, if it possible to have stepping issue which are not coming from the nema motors and the motor drives!??
Could it be an issue with the BOB, or MACH3? Example would it be wise if I increase the STEP pulse to 10 or 15 us? Also, why is the phenomenon only in the X axis, I mean the Y is identical to the X axis... and the Y axis carries more weight for sure!!!
Also one last thing - I failed to mention that I am running x16 mircostepping (3200)... and there are no reasons why I am running this many steps. Its just the motors run very smooth and having some hefty motors coupled with a lead screw, I wasn't concerned about torque...that much.
Also if it helps, when I mentioned of losing steps, I mean that the motor would literally stall for an entire command, or even more, I think. But want I mean is that its noticeable and I am not talking about 1 or 2 steps.
Anyways guys, any information would be helpful at the stage, as I am out of options.
Dim
