UC300 ETH-UB1
Results 1 to 3 of 3
Thread: UC300 ETH-UB1
    Default UC300 ETH-UB1
    Hello Gents
    What is this 5V port used for on this UC300 ETH-UB1 board?
    Is this to power the ENABLE terminals on the DQ542MA stepper motor drivers?
    Using the X axis as an example, I connected the stepper drivers as follows:
    XS+ to PUL+
    XS- to PUL-
    XD+ to DIR+
    XD- to DIR-
    I have not powered the board up yet,through the 24V power supply, so do not know yet, if there will be 5V available at that terminal on the board? Or must a 5V DC power supply be connected to this port?
    Regards
    Craig
    Attached Thumbnails Attached Thumbnails UC300 ETH-UB1-dscn0548-jpg   UC300 ETH-UB1-dscn0549-jpg   UC300 ETH-UB1-dscn0546-jpg
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: UC300 ETH-UB1
    You can use it to power anything that needs 5V, up to 500mA.
    Do NOT connect a power supply to it.
    UCCNC 2017 Screenset
    Quote Originally Posted by ger21 View Post
    Hello Gerry
    Thank you for your response. Pity that this 5V terminal, is not enough power for the proximity sensors.
    So it could be used to ENABLE the stepper drivers, if required to?
    Regards
    Craig
UC300 ETH-UB1
UC300 ETH-UB1
