48v AC stepper motor driver advice ma860h
Results 1 to 7 of 7
Thread: 48v AC stepper motor driver advice ma860h
    Member Jacare's Avatar
    Mar 2020
    Default 48v AC stepper motor driver advice ma860h
    Hello,
    I have a 48v AC stepper motor and need to buy a driver to control the motor.
    I was looking ma860h driver. Someone have feedback about that driver? Any other suggestion?
    Best regards.
    Apr 2004
    Oakland CA USA
    Default Re: 48v AC stepper motor driver advice ma860h
    Every stepper I've ever seen ran on DC. Are you sure yours is AC? Are you sure it's a stepper motor?
    Andrew Werby
    https://computersculpture.com/
    Member peteeng's Avatar
    Jul 2018
    dum dum
    Mar 2020
    Quote Originally Posted by awerby View Post
    Well, not so sure.
    Motor ref: HY200 3437 0660 AK04
    I cant find all the information about the motor. I know its hybrid, have 4 leads, 2 coils and 6.6A phase current.
    I assume it was AC because with the motor have a transformer to 48V but i dont find any retifier circuit, but i can be wrong.
    Can i make any test to see if it is AC or DC ? maybe using it as generator ... ?
    Thanks for your answer.
    Jul 2018
    dum dum
    Hi Jacare - A stepper motor runs on pulses provided by the driver. The driver can accept AC or DC and the driver rectifies it onto the correct waveform. Peter
    Mar 2020
    Quote Originally Posted by peteeng View Post
    Hi Peter, it makes sense now. So basicly its not important if it is DC or AC because the wave will need to be retified for the pwm provided by the driver right?
    Thanks for your anwser.
    Best regards.
  7. #7
    Jul 2018
    dum dum
    Yes you got it. Check the input voltage specs for the driver in its manual. Good luck Peter
