Does anyone know this stepper motor?
Results 1 to 10 of 10
Thread: Does anyone know this stepper motor?
    Default Does anyone know this stepper motor?
    I've looked everywhere. I can't find the datashet Do you have any guidance for me?
    Please
    Attached Thumbnails Attached Thumbnails Does anyone know this stepper motor?-img-20200325-wa0003-jpg
    Nov 2013
    Default Re: Does anyone know this stepper motor?
    what you you need from the spec sheet?
    Is there something about the stepper that you cannot measure or otherwise deduce?
    Craig
    Aug 2017
    China
    It look llike that motor from China , do you want to get a new pcs one ?
    Nov 2013
    Rubbish, it is a two phase Vexta stepper made by Oriental Motor Co, Japan......its as good as stepper motors get.
    My mini-mill is powered by Vexta 5 phase steppers and ultra low lash planetary gear reductions and Vexta drives....all absolutely superb.
    Craig
    Thank you for your help.
    I need to change this engine, and I don't know which features to analyze for the purchase ..... What should be analyzed to buy an exactly identical engine
    Nov 2013
    Why? Vexta steppers are class leading quality, if its not broken then is there need to change it?
    Steppers follow NEMA size recommendations. Is it a 17 size, 23 size, 34 size? By that I mean 1.7 (or 2.3 or 3.4) inch across the flats
    of the mounting flange? Thereafter just about any stepper will work. If you want to use it for CNC purposes and therefore want it to run
    fast then you MUST select a low inductance replacement.
    Craig
  7. #7
    The stepper motor is defective so I must replace it.
    But there are other parameters besides their dimensions, such as torque, phase, number of wires, pitch. Or not?
  8. #8
    Dec 2003
    The spec's on the motor will get you started, volt/current , the No. of wires is 4 for Bi-polar, more than 4, Unipolar.
    I have the Vexta Cat. going back to 1994/95 but does not show that model.
    Thanks,,,, AL
    What characteristics should I observe to choose an equal step motor?
  10. #10
    Dec 2003
    It is a little hard without knowing the full specs of the motor, but there are guides on the Gecko site that may be of help.
