Need Help! HELP HELP WE NEED HELP
Results 1 to 12 of 12
Thread: HELP HELP WE NEED HELP
    Jul 2013
    Default HELP HELP WE NEED HELP
    I’m trying to complete this CNC router for school.
    I teach boys (14-19) in lock up. I’ve promised them I can change their world if they let me.
    CNC routers have changed mine.
    I’ve wired the motors to the drivers correctly.
    I gave proper voltage in and out.
    I’m just paralyzed with fear in completing the wiring of the motors to the B.O.B.
    I’ve researched You Tube, but I can’t pull the trigger.
    Can you help me get this done?
    I know I’m close.
    Sent from my iPhone using Tapatalkhttps://uploads.tapatalk-cdn.com/202...9350f40df0.jpghttps://uploads.tapatalk-cdn.com/202...e5b06868f9.jpghttps://uploads.tapatalk-cdn.com/202...bac4746999.jpghttps://uploads.tapatalk-cdn.com/202...3a6f8365a0.jpghttps://uploads.tapatalk-cdn.com/202...b662e76b87.jpg
    Apr 2010
    Default Re: HELP HELP WE NEED HELP
    I think you mean wiring the drivers to the BOB, not the motors.
    You are close. The details you are missing are normally supplied with the drivers and you should look carefully at that documentation. You can find it here: https://www.automationtechnologiesin...oad.php?id=242
    Jul 2013
    Yes
    I have this.
    Just little scared about doing the wrong thing.
    Nov 2014
    Yeah I think your big power supply needs to be ran to your drivers and not through the BOB. I have only wired a setup once but it worked the BOB I used only used 5v but is different than yours for sure. What BOB is that? And what motors are you using?
    Jul 2013
    The BOB is a Chinese one of course.
    6 Axis for Mach 3
    The motors I believe are bi-polar
    Apr 2010
    Those drivers have a built in power supply.
  7. #7
    Mar 2003
    Shelby Township
    Do you have any documentation on the breakout board? Not sure why you would have two power supplies wired to it? What voltage are those power supplies, and what terminals are they wired to??
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  8. #8
    Jul 2013
    Ger21
    I’ll have to get back to you.
    Everything g us at school and I’ll be back in Tuesday
    Thank you for your interest in helping.
  9. #9
    Community Moderator wendtmk's Avatar
    Dec 2005
    Have you contacted CNC Router Parts/Avid for tech support help on your CNC Router Parts/Avid machine?
    Mark
  10. #10
    Jul 2013
    Never heard of it!
    So no.
    I’d like to check it out
    Thank you
  11. #11
    Nov 2014
    Did not even notice those were ac drivers. That break out board is interesting for sure. I found this description for it on amazon and googled it 0 documentation but there is an instructable may be worth looking at as it had a pic I couldnt read on my phone.
    Keenso DIY CNC 6 Axis MACH3 USB CNC Motion Controller Card Interface Engraving Machine Interface Breakout Board
  12. #12
    Jul 2013
    Another person in this conversation supplied the actual info.
    I’m going to print it out and try to follow it.
    I do appreciate your help.
