Building my first CNC - final questions - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
Thread: Building my first CNC - final questions
  1. #21
    Member nejc1337's Avatar
    Oct 2019
    Default Re: Building my first CNC - final questions
    Thank you, but I will go with these motors now: https://www.ebay.com/itm/NEMA23-23SS...7/163907492964
  2. #22
    Member ericks's Avatar
    Sep 2019
    Exciting....enjoy the build
  3. #23
    Oct 2019
    Thank you! And thanks to everyone who helped.
  4. #24
    Oct 2019
    I still need some help.
    So, this is what I have:
    - 48 V power supply
    - 4 of these: https://www.ebay.com/itm/264045184820
    - 6 limit switches: https://www.ebay.com/itm/10x-KW12-3-...UAAOSwA3xcNeRi
    - and probably something like this: https://www.ebay.com/itm/AC110-220V-....c100005.m1851
    What breakout board/controller do I need with these? I would like to incorporate everything from above, including limit switches and spindle. I suppose something like this won't work: https://www.ebay.com/itm/1pcs-5-Axis...kAAOxyBjBTWMPR
    Thanks a lot, guys!
  5. #25
    Aug 2009
    That spindle is not a brushless motor; I'd give serious consideration to getting one that is brushless. If the text of the listing doesn't say; you can tell one that's not brushless by the number of wires coming out of the motor: brushed motors have 2 wires, brushless have typically three (although it's possible to have more than three, in order to function it needs at least three wires).
    I don't use UCCNC myself (I have my own fork of Grbl-Mega); but from a quick look at the product page; I think a UC400ETH board plus one of those breakout boards you linked to, plus a parallel port ribbon cable (26 pin 0.100 header connector to DB25 female) should work for you.
    This is the sort of cable I think the UC400ETH needs:
    https://www.ebay.com/itm/LPT1-parall...C/372748413893
    That one comes with a PC case bracket on it; which you wouldn't be using, to get it off, just remove the screw mounts from the side of the DB25 connector.
    Note that the USB plug on that breakout board is only used to power the buffer chips on the board; there's no processor on it.
    Gerry - can you confirm that what I said is right?
  6. #26
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Yes, I think so.
    I'd use a handheld router as a spindle before I bought one of those cheap so-called "spindles".
    UCCNC 2017 Screenset
  7. #27
    Sep 2019
    I also use the uc300eth....very happy with it
  8. #28
    Oct 2019
    Thank you.
  9. #29
    Oct 2019
    For the 12-24 V power input on the breakout board, what current do I need to choose? Is 24V1A enough or should I go with 24V5A? Thank you.
  10. #30
    Sep 2019
    I have used the 5 axis board before, i actually have a few lying around. Tested them with 12 and 24 volts. Honestly i found the voltage regulator was getting very warm when i used 24V...so i opted for 12V.
    These boards work quite well. The power supplies i use are usually around 2A
  11. #31
    Sep 2019
    The AXBB-E motion controller has an inbuilt bob. I just got one today, same motion controller as with the UC300ETH. Worth a look i think!
    ...oops forgot to mention with the AXBB-E you need two power supplies, a 5V and 24V
  12. #32
    Oct 2019
    Oh, I see, thanks. So it does not matter at all if I use 12V or 24V?
  13. #33
    Sep 2019
    Quote Originally Posted by nejc1337 View Post
    Not a problem....
