Need Help! New Machine Build No movement. Please Help.
Results 1 to 1 of 1
Thread: New Machine Build No movement. Please Help.
    Dec 2005
    Default New Machine Build No movement. Please Help.
    Trying to get movement on my new Avid CNC machine but no dice.
    I have to be missing something simple.
    IDK if I need pull up resistors or if I need to do something to enable the drives.
    1) I have checked the parallel communication showing 4.10v / 0v like it should be at each DIR Pin terminal block on the BOB output when I change key stroke/directions.
    2) Motors are locking, all drivers are green.
    3) Motor polarities are all correct.
    4) Dip switches are set to 10micro and 3A, DIP/S #4 set to Half Current)
    5) BOB Input voltage is 19v on 15-32v pin and 5v on 5v input pin.
    Here is how I have everything wired (Ignore VDF connections on this BOB PDF)
    https://www.automationtechnologiesin...ng-Diagram.pdf
    Here is my drivers PDF.
    https://www.omc-stepperonline.com/download/DM542T.pdf
    Any help would be greatly appreciated. TIA
