Help with stepper/driver needed (low holding torque?)
Results 1 to 16 of 16
Thread: Help with stepper/driver needed (low holding torque?)
    Default Help with stepper/driver needed (low holding torque?)
    Hello people.
    Bought a laser cutting machine, xy gantry, nema17 motors, M415DRV drivers.
    Trying to debug very small oscillations happening while travelling at speed.
    Gantry and head driven by GT2 belts on your usual pulleys for that sort of thing. Think 3d printers.
    Usual speed for cutting paper card is 200-300mm/s, where i see small sinusoidal waving in the
    produced cut, always at opposite sides of, say, circle.
    Engraving in X at 400mm/s does well (tiny Y steps), but as soon as wide vertical motions are introduced
    i get waving in the cut. And sometimes step loss in Y direction.
    Checked mechanics, no binding or sticking.
    I'm thinking i may need to increase current to the motors to see if waving goes away with more torque.
    Cannot identify steppers to see their specs (china, right?).
    Markings on motors:
    X axis (head motion): Type 17HA705Y-1A, FH171215 Smooth (shorter motor, single shaft)
    Y axis (gantry motion): Type 17HA801Y-22P5, FH190104 Smooth (taller motor, dual shaft)
    Google-fu fails me on this.
    Same with drivers, cannot find M415DRV as such. I did find M415 but those have 6 switches on them, mine got 8.
    On my drivers switches 1 and 4 are ON. How do i increase current ? What switches to pull ?
    Attached Thumbnails Attached Thumbnails Help with stepper/driver needed (low holding torque?)-img_20190531_111403-jpg   Help with stepper/driver needed (low holding torque?)-img_20190604_225043-jpg   Help with stepper/driver needed (low holding torque?)-img_20190604_225244-jpg   Help with stepper/driver needed (low holding torque?)-img_20190604_164209-jpg
    Help with stepper/driver needed (low holding torque?)-img_20190604_163941-jpg
    Member john-100's Avatar
    Mar 2007
    uk
    Default Re: Help with stepper/driver needed (low holding torque?)
    a quick web search did not find your version of the M415DRV stepper driver
    can you post a close up of the switches and label ?
    with a readable picture of the current table it will be possible to see what the motor current is set to
    how hot are the stepper motors ?
    usually they can run at 70 or 80 C - too hot to touch !!!!!
    the other detail that's needed is the microstepping the driver is set to
    with full step to 1/4 you will likely see the motor jitter and have the lead screw resonate
    1/8 microstepping is usually a good start - with a 200 step per rev motor it will take 1600 steps for 1 revolution of the motor
    John
    Havent run the machine hard enough to see if motors are getting hot.
    Label is visible in the photos i attached to my first post. Switches 1 and 4 are in ON position.
    #Edit# pics got smallified after uploading. Re-attaching cropped image.
    Attached Thumbnails Attached Thumbnails Help with stepper/driver needed (low holding torque?)-img_20190531_111403_closeup-jpg
    Mar 2007
    uk
    The odd thing about stepper motors is the stepper driver sets the motor current and is constant irrespective of the mechanical load
    Depending on the setting of switch 5
    your stepper drivers automatically reduce the current to 50% when the motor has been idle for a while
    with switch 5 set to full the motor will heat up when it stopped
    what is the setting for switches 5 to 8 ?
    John
    PS
    did not see the new photo while posting !!!!
    5 is in OFF position.
    Mar 2007
    uk
    OK ,
    5 off = 50% current reduction
    with switches 6 to 8 set to off , on , on = half step
    I would change to 8 microsteps off , on ,off
    with switches 1 to 4 set to on , off , off , on = 0.5A RMS
    how did you decide to set set the current to 0.5A ?
    John
    Last edited by john-100; 06-05-2019 at 10:43 AM. Reason: correct initial microstep setting
  7. #7
    I didnt, it came from the factory this way.
    I suspect motors bouncing on direction changes, which (in my limited understanding) suggests not enough holding torque/current.
    And as i cant identify the motors, i dont know their amp range. Driver label seems to suggest max IT can do is 1.6A.
    #Edit# Only switches 1 AND 4 are in ON position. 2 and 3 are OFF.
  8. #8
    Mar 2007
    uk
    you could try increasing the current setting to 0.57A RMS
    switches 1 to 4 = on , off , off, on = 0.5A RMS
    the next current setting is off , off , off , on = 0.57 A RMS ( a 14% increase)
    Help with stepper/driver needed (low holding torque?)-current-setting-jpg
    for your tests set switch 5 to on to switch off the auto current reduction
    it will make it easier to check the motor temperature does not go higher than 80 C
    example stepper motor data sheet
    RS Pro H i g h T o r q u e H y b r i d Stepper Motor.pdf
    John
  9. #9
    Running torture test at the moment. Loaded a complex design and let it run with laser off.
    About 15 minutes of very small movements, sudden direction changes. Dont know if its losing steps, just want to see if motors get warm/hot on default settings.
    #Edit# Results. X motor (head) about 40C, Y motor is 20C, ambient about 18C. Thoughts ?
  10. #10
    Mar 2007
    uk
    I would expect the will be too hot to touch unless the motor is being under run or the auto current reduction is keeping the motor cool
    see data sheet
    John
  11. #11
    Starting to get a hang of this.
    Will change to 0.57 and test again.
    Here's another question - what does microstepping decrease do to torque ? I'd assume it will increase torque and travel distance (if not corrected in controller software).
    Am i correct ?
  12. #12
    Mar 2007
    uk
    yes
    increasing microstepping is a trade off between a smoother movement and loss of torque
    you will need to compensate for an increase microsteps in your control software
    John
    PS
    just thought
    the wavey edge could be due to a miss match in pitch between the toothed belt and the toothed pully
  13. #13
    Belts and pulleys look like GT2 on my 3d printers.
  14. #14
    Increased current to 0.57A
    Ran the torture test again. Twice in a row.
    Results:
    X is burning, 65C
    Y, stone cold.
    While X is a shorter motor, both motors do about the same amount of moving yet X is getting a bit close to 80C, while Y is sitting there just yawning. Never seen stepper to heat up so much on any of my other devices with nema17 motors...
  15. #15
    Mar 2007
    uk
    From the photo showing both drivers it looks like they have the same switch settings
    with one motor hot and the other cold
    first I would check the wiring between Y axis motor and Y axis driver
    if the wiring is OK
    swap the 2 drivers
    so the X axis step & direction signals and X axis motor is connected to the Y axis driver
    and the Y axis step & direction signals and Y axis motor is connected to the X axis driver
    to see if the problem moves to the motor or stays with the driver
    John
  16. #16
    Good idea. Will swap out the drivers and report back tomorrow.
    Any idea on origin of the steppers ? Cant find anything on these models.
